Beginner Help, how do i post a picture on the forum
mrya
hello
Newbie to the forum
How do i post a picture on the forum? I tried copy/paste and did not work.
I cant see anywhere where it can be sent as an attachement either.
thanks
If you go to the tutorials forum and have scroll through, you will find a couple of different methods of how to upload photos.
I have a feeling you might need to be a member for a while (short!) and have a certain number of posts (not excessive) before you can post shots or links. I'll tag a mod or 2 ( @Cobra , @Marcel ) who should be able to advise better.
hello
Newbie to the forum
thanks
You can't copy and paste, if you want to attach a file from your device use the middle button bottom right of the reply box.
Baring in mind that the it has to fulfil the criteria.
If attaching a file direct from your PC / device, into a thread.
this must not exceed 1024px on the longest side or 500Kb
otherwise it will fail to up load.
You also have Gallery space, how to is here
https://www.talkphotography.co.uk/t...o-and-insert-an-image-from-your-tp-gallery.8/
Or if you use Flicker a "by the numbers" guide is here
https://www.talkphotography.co.uk/tutorials/inserting-images-from-flickr-updated-22-08-15.7/
