HD question (Not HDR)
Glen
Uncle Glen
Glen
Any other peeps out there got a HD setup?
I've just got my HDMI leads yesterday and hooked up the new PS3 to my new TV and tried the Planet Earth Blu-Ray I got last week. I was amazed how good the quality is, blown away totally :eek:
Does Sky HD offer this level of quality?
My TV is a true 1080p TV, is Sky HD running @ 1080 or is it less.
Basically is it worth the extra £10 a month and what ever the Box will cost, say £200?
Ta.
Some of sky's HD content is upscaled SD tv, but newer stuff like torchwood was made and broadcast in 1080p iirc
I think you will find the highest broadcastable quality at the moment will be 1080i (interlaced) you will only get 1080p (progressive) from Blu-Ray or HD-DVD Discs
More info
Progressive vs. Interlaced
Interlaced video has been around as long as there have been televisions with cathode ray tubes (CRTs). All analog television standards are based on interlaced video, and we're so used to it that it's not something that we typically think about. High definition video can be either interlaced or progressively scanned. It's important to understand these terms, and it's really not too difficult.
Progressive scan video is scanned from side to side, top to bottom: line 1, line 2, line 3 etc, up to the end of the frame. It's as simple as that. In fact, it's exactly how you'd expect video to be scanned if you didn't know any better!
Interlaced video is scanned from side to side, top to bottom, as well. The difference is that every 60th of a second, every other line making up the complete frame is scanned. Then, a 60th of a second later, the lines in-between the lines that have already appeared are scanned. Effectively, half the picture's vertical resolution is sent in the first 60th of a second, and the second half is sent in the second 60th of a second. When the video is played back, the whole thing happens in reverse, giving the appearance of a complete frame. Each of these "halves" of a frame is called a "field."
The effect to the viewer is quite distinct. First, the image doesn't flicker as much as it would if it was a simple 30 FPS progressive scan. This is because, to the viewer, it looks as if they are seeing 60 frames per second. Of course, what they are actually seeing is 60 fields per second; but for flicker reduction, the effect is the same as seeing 60 frames.
If you were to look at an interlaced picture on a screen for a 60th of a second, you'd only see half the vertical resolution — every other line. But, because our eyes and brains conveniently offer a "persistence" effect, when you look at the screen "normally," what you actually see is something approaching full resolution. Persistence allows us to accumulate visual data from the two distinct fields, making them seem like one complete image.
720p and 1080i
Progressively scanned high definition video tends to have a resolution of 1280 by 720 pixels, normally referred to as "720p", where the "p" stands for progressive. Likewise, “1080i” is interlaced video with a frame size of 1920 by 1080 pixels. Interlacing is actually a form of compression. Offsetting the two fields making up a frame by half a frame's duration, halves the total amount of information needed to transmit or store the video. Uncompressed interlaced high definition video generates around a gigabit per second. Without interlacing, the rate would be twice that.
24p
There is a special case of progressive scanning, known as 24p. Twenty-four frames per second sounds very slow, but it's used by some video systems to mimic the frame rate of film. HDV doesn't support 24p directly, but some cameras can emulate it using a technique called "pulldown." Pulldown converts a lower sampled framerate to a higher framerate for display by repeating fields from adjacent frames. Camcorders that emulate 24p take samples at 24 fps, then apply pulldown to produce interlaced 30 fps video to be HDV-compliant.Thus there's really only 24 frames-per-second of distinct information, but the stored video is standard 29.97 frames-per-second interlaced data.
Disadvantages of Interlaced and Progressive
Interlaced video does have some disadvantages in comparison with progressive. It's prone to causing "artifacts", which look like a kind of "comb" effect, especially in slow motion or in still grabs from moving video. They are caused by the relative movement between two fields that make up a single frame. It's a fact of life, though, that 1080p, (1920 by 1080 progressive), which might appear to be the perfect format for high definition video, would generate too much data for current consumer technology, so we might have to wait a while for that. Rest assured that your Canopus technology, which is completely resolution independent, will be able to handle it, if it ever does appear.
eh :thinking:
Think i will have to sit and read this one a few times :lol:
If it helps, i've had an expensive old week starting with a 42" plasma and a ps3, finishing today with a V+ box from virgin. My tv isn't full 1080p, but is hooked up via hdmi and the V+ box is set up to display at 720p. Some of the SD channels look outstanding and watching Planet Earth via on-demand HD is fantastic!
As has been said, you will only really get a true 1080p picture from Blu-ray. Even PS3 games are just upscaled (so i've been told) froma native 720p source.
Had a chat with the engineer who has sky hd, but he also said he only had it because he can't get cable where he lives. Make of that what you will :)
i've got a philips aurea and even the SD is awesome due to the 100hz. Sky HD is just the extra tenner and has to be well worth it. I've even connected the macbook via hdmi and that's pretty cool :D
