Cheers les will keep that offer in mind m8 would like it to be early as can get a dawn shot of Glastonbury tor .Ham Wall side is still passable but very muddy- the Shapwick end is clear though- use the small car park and follow the path along the canal, when you reach the bridge, turn left for a hide where Kingfishers like to be around and its on stilts so commands a nice view, get there early is my advice
Greylake has 2 hides and a willow screen, all accessible but a long lens is required to get any half decent shots as the water is a fair way out from the hides, nice to walk around the reed beds too but stealth is a definite must, once again an early start is required
drop me a PM if you fancy a meet and a guide
Les
On Golden Pond by Les Moxon, on FlickrThat's the one that made me want to get there early les lol .
Early Light over Glastonbury by Les Moxon, on Flickr
Samyang 8mm Mono by Les Moxon, on FlickrI'll watch this thread as if it's the 22nd I might tag along.
22nd should be okay with me ... @Lez325 do you know if the main car park and track will be back in use?
I'll have to check work commitments and weather closer to the time but if it's all looking good I'll hope to be there (early - for that great shot of Glastonbury Tor at sunrise and the mist drifting over the water..........!)
DSC08264 My view by Les Moxon, on Flickrwell the long range forcast look good and I will definitely be in the car park around 7am
Les
Did someone mention "Sunrise"
Les
Plenty of time for the Met Office supercomputer to change its mind then............
Stop doing this to us Les...........!
Sunrise on the Levels by Les Moxon, on Flickr
Orange sunrise by Les Moxon, on FlickrJust had an email response from RSPB Ham Walls which says, in part, "the bridge will be closed for at least another week whilst work continues sand blasting and painting.".
This means that normal access is not possible and access can only be gained by entering the site from around the back somewhere and trekking up some muddy tracks ... I'm probably going to give it a miss this time.![]()
you don't fancy Shapwick then Roger?
What would you recommend then lez out of Greylake or Shapwick either one I don't mind just be good to get out for few hrs
I personally love Greylake Mark- nice reed bed area and 2 decent hides, not too far to walk from the car park either,
So that would be my personal venue of choice
Les
Path is now open.
