mike weeks
- mike
- No
The Godox updates page is at http://www.godox.com/CN/Downloads.html in Chinese but most browsers can translate to English.
If trying to use the updates on a Windows 8 or 10 machine you first need to set the computer to allow unsigned drivers and after that run the install programs followed by the firmware upgrade. a further issue I found with the AD360II-N upgrade is that the system does not like being run from a folder with Chinese characters in the name so I simply moved to the desktop and ran from there.
I found the following info online
I have used this successfully on the new XI triggers and receivers as well as the aforementioned AD360II-N and just need to do a couple of V860s
Mike
Updates from http://www.godox.com/CN/Downloads.html
I have successfully upgraded the driver with Windows 10, here is what you need to do:
1. Do NOT connect the flash/trigger to the computer at this point. If you have already connected the device to the computer prior to the installation, you might have problems as the computer registers the device as unknown, and after that it gets pretty hard to make the computer disregard that.
2. Check the software version on the device and make sure you’re not already running the version you are updating to. If you’re running the latest version, there should be no reason to upgrade.
On X1-T:
Turn device OFF. Hold the MODE button pressed, and turn the device ON. The firmware version will be displayed.
On X1-R:
Turn device OFF. Hold the GR button pressed, and turn the device ON. The firmware version will be displayed.
On TT685C:
Press the C.fn button and the firmware version will be displayed at the top right corner. Note: The same works on AD360II
3. Disable Driver Signature Verification using this guide: http://www.howtogeek.com/167723/how...8.1-so-that-you-can-install-unsigned-drivers/
4. Once the computer has restarted, run the installation and choose to install the drivers (even if you have installed them before). Make sure the installation has completed successfully. If there is an error with installing the drivers, try to correct the problem before continuing.
5. Let the installation install Java 7. I have not tested the software with later versions of Java, even though later versions were available.
6. Turn the device OFF and connect it to the PC using a USB cable. The display of the device will not show anything, but your PC should make a sound that a new device has been connected to it successfully, you might not find any new devices under the “Device Manager” in Windows, this is normal.
7. Run the firmware update software, make sure it is connected to the device and start the process.
8. After the process has finished, the display on the device might be on. Disregard that and unplug the device from the PC.
9. Check the firmware version on the device and make sure that it has updated.
10. Restart your PC to return to the normal driver signing verification mode in Windows.
Note: If you ever update the firmware for a different device (Transmitter/receiver/flash/whatever), repeat this entire process, including reinstalling the drivers. The drivers that are included with the firmware update software for flash triggers seem to not be working well with the flash, even though they show up under the same name.
Mike
