graycbr
- graham
- No
hi guys
Just found this new flash any good ?
specs quite good , with good reviews what I've found they seem ok ...
Product details
Characteristics
Quite like the battery pack with this as well ???
Product details
- Wireless trigger sensors: Remote sensing CELL 2 mode for off-camera TTL flash synchronisation .
- Increase the power source with the Gloxy GX-EX2500 external battery pack : this will give you a higher call back rate.
- Quick call back: 0.1 - 6.0 sec.
- Supports high-speed continuous shooting: 1/16
- Power-saving mode: When the flash is inactive for 20 seconds, the backlight will turn off after 20 seconds, after 60 seconds it will go to sleep and after 30 minutes it will automatically shut down.
- High-precision output: from 1/128 to 1/1
- Overheating protection: improved built-temperature detection
- HSS: High Speed Sync up to an impressive 1/8000s
Characteristics
- Circuit design: insulated gate bipolar transistor (IGBT)
- Guide number: 54 (ISO 100, 105mm)
- Flash modes: TTL / M / RPT(repeat) / MA (semi-automatic)
- Zoom range: Auto, 18mm, 24mm, 28mm, 35mm, 50mm, 70mm, 85mm, 105mm, 135mm, 180mm
- Bounce: 0 to 90 degrees
- Swivel: 0 to 270 degrees
- Flash control: 8 grade high-speed control (1/128 - 1)
- Recycle time: approximately 0.1 - 6.0 sec.
- Peripheral interface: hot shoe, PC mount, external charge mount
- Power: 4 x AA size batteries (alkaline or Ni-MH are usable)
- Lighting time: 100-1500 times (using AA alkaline cell)
- Wireless distance: indoor 20-30 meters, outdoor 10-15 meters
- Addition features: PC synchronous , sniff mode, over temperature protection
- Colour temperature: 5,500K
- Lighting time: 1/200 to 1/20000s
- Dimensions: 200 x 75 x 57mm
- Net weight: 340g
