Gilly B
- Gillian
Maths was never one of my strong points, and the modern technology associated with photography gets the better of me - most of the time. The advice I am looking for from you pros will hopefully help me understand which lens I should have used yesterday.
I photographed a group of people (36) as a family portrait and overall was quite happy with the results. I used both cameras set up as follows:-
5D fitted with 24-105mm L and ISO 100, and my 20D fitted with 50mm 1.4 ISO 100 and 580EX on both camera with the wide angle screen down.
I took the first 5 shots not too far away from them and varied the distances in each shot between 32mm up to 65mm.
I then swapped cameras and had to walk right back to fit everyone in (as I expected due to the crop factor) and preceded to take the other 6 shots.
When I loaded them into my PC and going through the process of reviewing them, I simulated a 20"x16" crop and printed out 1 image from each camera to compare the resolution. The results have left me puzzled - as the faces on the image taken with the 20D are much larger and very clear as opposed to the image from the 5D at 65mm cropped to 20"x16" which is smaller and not that clear on the faces.
Could someone point me in the right direction as to which camera should have had the 50mm and which should have had the 24-105? :shrug: I have a wedding on Saturday, and whilst my confidence is growing by each event, I am keen to get it right in camera and not rely on PS just because I shoot in RAW.
I hope I have made sense above. I understand what I mean, I hope you peeps do too. Gillian
I will post an example in a mo...
