johnnypanic
- John
Recently purchased, Focal pro, to calibrate my Sigma 150-600 contemporary. As I have the Sigma dock, I was able to calibrate at 16 combinations, of focal length and distance. All seems fine, with a few variations, of a few fine tune points here and there.
Also decided, as I have the software, to calibrate some of my other lens. Firstly, the Tamron 24 - 70 2.8 and the Tamron 70 - 200 2.8. This is where the problems begin
On the 24 - 70, fine tune values were +4 at the 24mm end and - 5 at the 70mm end. Also tested at 50mm, which gave a value of -3.
Even more problematic, is the 70 - 200, which gives a value of +5 at the 70mm end and - 18 at the 200mm end!
These were calibrated, with my D610, so will run the tests again on the D610 and also run on my D500. But, if the variances are as dramatic as this, what are my options?
Thanks in advance for any guidance.
