Fluid heads
WillNicholls
Will
Hi
I'm going to Cambodia on an expedition to film some wildlife out there.
Long story short, I'm shooting with a Nikon d4 and 200-400mm f4 lens.
Heavy kit. I have a wimberley head at the moment. Will this do? I use it at the moment but it takes a lot of skill to get smooth images when following things.
I think I'd probably be better with a fluid head? Any recommendations? On a tight budget, but would like to see what's out there. Thanks.
Canon 60d battery pack and 70-200 sigma big lens seems fine on the 128rc however see your point
Ooh boy. You're going to want the biggest, heaviest legs and head that you can afford for that level of long lens stuff....especially if you're using the d4 video crop mode.
Can't help specifically I'm afraid, it's pretty specialist....
WillNicholls said:
Hi guys,
Sorry to revive this but been doing more research.
The manfrotto 501hdv head that Jacob recommended has been recommended to me by another photographer as very good for this setup.
Anyone else used this?
Will, Manfrotto have just released a new light weight head that uses the bridging technology that is worth checking out too
Will, especially for long lens stuff, I'd run very fast away from the 501 I'd I were you... The 502 is ok but probably not stable enough for long lens....
WillNicholls said:
How come? I only ask because I know people using it with the same set up that think its great.
Fair enough.... Whenever I've had to use one (though to be fair I am used to the bigger, heavier 504, or sachtler heads) its made me want to break it, just from not being... Fluid enough? Idk, try one first. I was impressed last year by the 502 head though, good price as well
I'd hang on buying the 501 for as long as possible ;), when is your trip?
