Flash power controlled by trigger
Philx1979
Phil
Hi I'm currently using youngnuo rf-602s to trigger my Nikon speedlights, are there any triggers and receivers where you can adjust the power of the speedlights from the trigger?
For example from my camera trigger I can see speedlight 1 is 1/64 and speedlight 2 is 1/32 and I can adjust power up and down without touching the speedlight but rather using the trigger?
Pixel kings are probably the next step up from RF 602's.
You can adjust in camera with them
You can do that using the pop-up in commander mode to control remote flashes from the camera, but if you want radio, then Pocket Wizard Min/Flex, Phottix Odin, or the Pixels
Cheers guys, took a look at the Phottix Odin`s they look pretty good and will do the job, crikey didnt know it was that much of a jump, think Wex do an offer 1 trigger and 2 recievers for £420, hmmm will have to weigh up whether to carry on adjusting power manually or pay the premium.
Oh i use full manual cos i like consistency cant be trying with the CLS.
Waiting for the Nikon fit Yongnuo 622s is (or will be) another option, if you are in no hurry.
CLS is great if you can live with the range issues, especially outdoors. I use my SU-800 with an SB-700 and SB-800 all the time these days since my Strato triggers died, and the quick power adjustment on the rear makes setting manual power settings easy.
