Flash head repair
Phil V
Phil
I've just ordered a replacement flash tube for an old (but brand new) cheap studio flash head. The flash hasn't been powered up for a couple of years, will it be safe to dismantle or will I have to discharge the capacitor safely? If I do have to discharge it are there any instructions online.
I'm totally new to repairing flashes although I am quite useful in the DIY stakes (including electrickery).
if the flash head has not been used for some years it will be dead and no volts will be on the capacitor, more of a problem is if the unit has not been used for years it may not charge up well and give problems. how many years has it been unused, what make / model is it. try to charge it up slowly or in short bursts , 1 second burts over several hours to give the capacitors a chance. the link you put up is for led lights, no flash tubes in there. david
I didn't put a link up, that's one of the forum's 'quirks'.:)
Thanks for the heads up on the charging of the capacitors. It's a cheap ebay flash about 5 years old. Used once and dropped it. The seller sent me a free replacement because they had no replacement flash tubes. But I've just found a replacement tube so I figure it's worth a pop as I'm doing a bit more 'lit' stuff and a 3rd head will come in handy.
