Flash gun triggers with Yongnuo TN622c
CarloUK
Carlo
Hi
I have a Canon EOS 6D (No flash)
A Canon 430EX II and a Manual Yongnuo YN560-II
My question is. If I purchase a pair of Yongnuo TN 622C wireless triggers can I mount one on my 6D as the transmitter. Then one on my 430EXII giving me full control from the back of the 6D. Then use the 430EXII to trigger the manual YN560-II flash.
Basically I have 2 flash guns and only 2 transceivers, so trying to trigger one optically.
Will this work or do I have to spend more money for 3 off TN 622C
Thanks Carlo
Yep should work , just put the 560 into slave mode . Just remember that you won't be able to change any settings on it remotely though .
Carlo - If you use the 430EXII in E-TTL mode, there will be an exposure-evaluation pre-flash, and this can give a false trigger to the 560, unless you use the right (S2?) mode.
In Manual mode, the 430 will not give a pre-flash.
