With B&W I snip the leader off the roll (assuming 35mm) and dunk it in the fixer to time how long it take to clear entirley. I tend to allow a bit longer to be on the safe side.
Agree with double the clearing time (and a bit, as clearing seems to be around 30 seconds for me, usually).You should fix for double the clearing time.
That was the instruction in the 50's and earlier.
When fixer is off it stinks.
Very little for the "dunk" test described above. Just enough to be able to hold in between thumb and forefinger and dip it in the solution. Double the clearing time seems a bit much to me but it's not going to do any harm. I’ve got negs form the 80’s that are just fine and dandy.How much do you actually need?
I'd say that's a bit long, I'd be mixing a new batch if it were me.took 3 minutes to clear
(Of course that leads onto the long and complicated story about what you should do with depleted fixer... T'internets are full of advice, but after reading lots of it I found a nugget from someone who actually appeared to have some appropriate environmental/chemical knowledge; the advice was, if you're a person doing occasional film processing rather than a lab, no need to take special precautions, it's unlikely to cause harm flushed down the drain... but note, I have no environmental or chemical expertise whatsoever, so this is NOT ADVICE!!!!!)
