Hodders
- Ben
Right,
Doorbell rang this morning with a bloke carrying a 3m x 2.5m roll of white vinyl from Tony Beals (they sell tarps for the haulage industry). Total cost £40 odd quid. As opposed to £100+ for the lastolite equivalent (smaller as well).
I have played around extensively with lighting the hilight using the two Yongnuo YN460-II leaving me with my 430EX-II and SB28 to use for lighting the subject.
The vinyl floor is great - very very slightly off white (creamish) with a slight shine on one side.
So the basic setup was hilite lit with the YN460s. The SB28 was aimed at the floor/hilite join and last light aimed at the subject above and just off to camera left. Wall was at f10, subject at f7 - so about a stop difference.
All shots are straight out the camera, resized and saved with a tad of sharpen. Subject was about 3 feet in front of the hilite.
ONE:
Pretty pleased with invisible join. Nice shadow but so much spill onto the dolls head which saps all the contrast and 'snap' from the image.
Next go:
Moved the 'join' flash and tried to shield the main subject from it. This resulted in:
TWO:
Not too bad, but you can see the join on the RHS where the fall off from the 'join' flash has fallen off - I might try a reflecter here to bounce a bit of light back.
Still loads of spill (look at either side of my face). If I turn the main llight off, you can still see how much illumination is wrapping round.
THREE:
But this last but one shot is usable with a bit of PP:
FOUR:
The next game is to try and get some black fabric and build a 'tent' in the stylee of EdinburghGary. This should help loads with the spill but might also make the floor trickier. Reflective flooring is not an option here as it need to be portable.
Comments and ideas will be VERY gratefully received.
ONE:
Next go:
TWO:
THREE:
FOUR:
