First Pro Wrestling shoot (first event shoot)
xlan
Alan
Hi
Decided to post here so I wouldn't hijack anyone else's thread!
I'm going to shoot independent pro wrestling as a complete amateur on Sunday. I have a few questions, I have the following kit: Canon 1100D, 50mm f1.8, 18-55mm kit lens, 55-250mm.
I assume ringside my 50mm would be too close? Kit lens then?
Would I need to use flash (pop up) if its too dark?
Should I get a cheap pop up flash diffuser off ebay?
Thanks for the help in advance :)
You really shouldnt use flash under any conditions... two competitors feet away and you want to flash them? not good at all..
get there early.. try the 50mm see if theres anough room.. if not then the kit lens..
Thanks for the info, I'll be getting there an hour early or so :)
