I can honestly say this is my first ever MF image and my first ever Polaroid ...
... put the two together and whaddya got ... :shrug: ... my first ever MF Polaroid ...
A really garbage image in technical terms but if you knew what I went through to get it you might forgive me for being so pleased with the result ...
I can also honestly say it took me a whole pack of film to get this single image ...
... it is the first out of the second pack ...
Anyway, the image ... scanned with my Dell all-in-one printer and sorted through Elements 5 to show on here ...
[/IMG]
A couple of things concern me a little ...
1. The black lines down the sides - I assume these are a cut off for the format on Polaroid film ?
2. There appears to be some vignetting - 50mm lens on RB Pro SD ?
3. The image is really rubbish - me or the Polaroid fillum ?
BTB I know it is suffering blown sky but I guessed at the settings having been through the proper loop a number of times earlier in the day as I wasted the first pack and was a little miffed off tbh ... :shrug:
There you go then ... the gear works so next step is loading the other backs with proper fillum and getting it exposed and processed ...
