Experimental cheap ’n cheerful multi-flash
Sam-D
Richard
I would like to do some experimentation with a cheap, portable, homemade, radio controlled, multi-flash system.
The plan is to probably use Cactus V2 units (sorry cherryrig!) and scrounge/buy old battery flash guns. However, the major drawback to my cunning plan appears to be the triggering voltage issue. The Cactus has a maximum trigger voltage of 12v and any old/affordable flash units are likely to be of much higher voltage, as they were designed for film cameras capable of handling considerably more than 12 volts.
So, do any of you flash savvy togs know a neat way around this problem? Alternatively does anyone know of an old/affordable flash unit that was designed to operate below 12volts?
Any help or advice would be most welcomed.
Thank you.
Sam-D
