stevewestern
My mum is 87, lives alone and is loosing it a bit, and a couple of times we have found the iron left on a few hours after she has finished ironing.
I would like some sort of timer that ideally can be fitted in-line that turns the iron off after say 30 minutes, or one you plug into the socket.
However, the plug in type (this sort of thing - https://www.screwfix.com/p/masterplug-digital-programmable-7-day-timer-240v/50676 - usually require some fiddling with and I can see her not bothering.
The only thing I have found that might do the job is this -
https://www.screwfix.com/p/elkay-3-wire-master-push-button-white/34572
I could then run an unswitched socket from it into which she could plug her iron.
Does anyone have any other suggestions please ?
