DOF on Full Frame...?
Desert Rat
Steve
Is the DOF narrower on FF compared to a crop sensor?
No. Not intrinsically.
But a FF sensor will require you to get closer to a subject for like-for-like composition, which decreases depth of field.
Yup. With FF cameras you may end up either closer to the subject or using longer lenses, both of which can make the DoF look thinner.
Also, if you stand in exactly the same position, using exactly the same focal length, a FF camera will produce an image with smaller *apparent* dof than a crop sensor. That is, the zone of sharp focus will occupy a proportionately smaller part of the image. However, this is just because your field of view is larger. The real dof is actually exactly the same. The same objects will fall within the zone of sharp focus with each camera.
That explains it perfectly. Thanks :thumbs:
There is no zone of sharp focus. There's a plane of focus, and a zone of acceptable focus which depends on magnification and viewing distance.
It's the magnification difference between FF and crop which gives the apparently different DoF.
Whilst it's true that magnification alters how you perceive the DoF I've always thought that camera to subject distance and focal length have a much more visible real world effect given that with a larger format you will probably be altering your camera to subject distance and/or using longer lenses regardless of how large you print or at what distance you view the image.
Therefore the format size can dictate the camera to subject distance and/or the focal length and therefore what the image will look like at any given image size or viewing distance.
PS. The best way to get it all straight in your head, IMVHO, is to theorise less as it only gives you brain ache and to instead shoot with different formats and view the results.
It's not true magnification though, is it?
Your field of view has just been expanded (all other things being equal) with the FF camera. So the "zone of acceptable focus", if you want to call it that (I don't care, we know what we're talking about), is a smaller part of the image. Proportionately.
The fact you've moved to a FF camera (again, keeping subject distance and focal length equal) has changed precisely nothing about the physics of the dof. A given focal length, aperture, and focus point will still produce the same *objective* zone of acceptable focus in terms of distance from the camera.
BUT.
For an equivalent field of view the DOF is shallower, is it not?
The difference between my Canon S90 and Nikon D700 is huge at the f/2.0 that is the widest the S90 goes.
Difference being that the Nikon is at 24mm and the Canon at 6mm or something. Yes, if you have a 6mm lens on the Nikon the DoF will be equivalent but a 6mm lens on the D700 would be silly, as is this argument.
BUT.
For an equivalent field of view the dof is shallower on FF because you have to be closer to the subject.
It's not really anything intrinsic to the FF camera.
Well. Yes it is. It's exactly intrinsic to the size of the sensor.
I disagree. Although we may be talking at cross purposes.
What I'm saying is that there's nothing about the FF camera *per se* that alters a dof for a given focal length, aperture and subject distance. It's simply the fact that to get an equivalent field of view you need to move closer to a subject. Moving closer to a subject decreases dof, everything else being equal. This is true of any camera.
It's not theorising it's physics. The only 2 variables that actually affect DoF at the film plane* are focal length and subject distance.
This is where it twists though, because the focal length effectively alters the general subject distancefield of view dependant on sensor size. So a 6mm lens on a FF sensor will have exactly the same DoF as it does on the compact. But it's impractical and more likely to be 24mm lens for the same shot, which then has a smaller DoF.
The other 'real world' twist is the real magnification that happens when an image is printed, because the size of print and viewing distance affect the apparent circle of confusion (what we see as sharp or blurred). Things which appear to be within the acceptable DoF on a small print will look OoF if the print is enlarged and viewed close.
So the DOF is directly proportional to the DPI :thinking:
(tongue so far in cheek it came out of my ear)
And will it always be the 'film plane'?:thinking:
I still 'tape' stuff on the telly that I want to watch later, despite the fact it's been on a hard drive for about 5 years?:D
The short answer is yes.
Longer answer, DoF is ALL about magnification - the relative size of all contributing factors. Sensor size, lens focal length, the diameter of the aperture, subject distance, circle of confusion, print size and viewing distance. Change any one, and perceived DoF alters.
Importantly, DoF cannot be measured or compared unless the final output size and viewing distance is specified, and the international standard for that is a 10in print, viewed from a distance equal to the diagonal, ie 12in, with a 0.2mm circle of confusion.
The reasoning behind the short answer relates to the way we work, ie the sensor size is fixed by the camera and we adjust all other considerations to suit that (focal length, distance, aperture). Therefore, sensor sizes drives everything.
I think I found a table somewhere which had a rough guide what fstop would look like at at different formats
Wow! I'm possibly more confuddled now...
The reason I asked is because I was playing with a lens on different bodies. One FF and the other cropped. At the same focal length and aperture, the crop sensor seemed to have a wider DOF. To acheive the same DOF on the FF I had to go f/16 or above from f/10......
The reality which has been sort of said already is with a crop sensor and 50mm lens, you will need (approximately) an 85mm lens on full frame to get the same field of view... It will have the same things framed in it. The fact that you will be using an 85mm lens instead of a 50mm lens decreases the depth of field.
Alternatively, keep the 50mm lens on the full frame camera and move closer to frame it the same. This will also lead to a shallower depth of field due to being closer to the subject.
So usually if you move to full frame you would have longer lenses to get the similar framing results and this leads to shallower depth of field. That's the way I did it anyway.
Basically what changes with sensor size is focal length needed to get the same field of view and as you increase focal length DOF at the same aperture will decrease.
Ghoti's argument might give people the impression that had you not "cropped" the image on a smaller sensor using a FF lens the DOF would be larger, this isn't the case, what would have changed is that you'd have used a smaller focal length on a smaller sensor to get the same field of view and that would have increased DOF.
I get it.:thumbs:
When comparing DoF with different formats, the difference is f/number x crop factor - with subject framed the same (by changing focal length or shooting distance), same aperture, everything else the same. Basically, it's just over one stop difference, and if the crop factor was 1.4x (square root of 2), it would be exactly one stop difference. Check it out with this DoF calculator http://www.dofmaster.com/dofjs.html
Going back to the magnification thing, DoF is an illusion - there is only ever one plane of perfect focus, but also a zone of acceptable sharpness either side of that point, defined by the circle of confusion standard. When the image is made larger - by any means, at any stage in the process - then that reveals more finer detail, which then looks less sharp, and so the DoF zone of acceptable sharpness is reduced.
I get it.:thumbs:
Looking back I actually got a bit mixed up in the second part, what I ment to say was that cropping a FF lens doesn't increase the DOF, it merely reduces the field of view.
Basically you take a shot with a 50mm lens at F2.8 on any camera system with the subject and the camera in the same positions DOF will be the same, what will change is the field of view.
One other thing that can change is that DOF is a product of resolution, theres no "in focus" and "out of focus" black and white situation, focus is actually a sliding scale and how large an area in focus appears to be depends on how much resolution your viewing as you can see bluring earlier. Since larger sensor(or film format) cameras tend to have higher resolution that's used for larger prints or more cropping DOF will appear to be smaller in this respect aswell.
That's exactly what I was saying.
Though this is an aspect that I hadn't fully considered. However, display medium, size and resolution will affect perceived dof, but they're not necessarily intrinsic to the FF format in and of itself. The best one can say (as you imply) is that certain things that can decrease perceived dof - like higher resolution - tend to correlate with FF cameras.
That changes the image completely. To make any valid comparison, the pictures must be the same - same framing (adjust focal length) and same viewpoint (to maintain perspective).
If you simply crop a FF image (same lens, same position) you are effectively using a crop format camera.
When you change any aspect, DoF changes. One thing affects the others and you have to re-run the calcs.
Sensor resolution is insignificant. If you calculate back from the circle of confusion, ie 0.03mm on FF, then that equates to less than 1m pixels total resolution. That may be a fraction of the camera's maximum potential, but it's not far off what you're usually looking at with an on-screen monitor image, and rather blows the popular myth that more pixels equals more sharpness ;)
