I was thinking aesthetically as well.
Well, it's been there for more than a year, and it replaced an earlier one from years earlier . . .THAT'S what I was looking for!![]()
An excellent summary, if we assume that softer light equates to better light. A bit like Animal Farm, "4 legs good, 2 legs bad" - an easy shorthand but too simplistic by half.Closer the light / bigger the light source to the subject, the 'better' quality of the light, ie softer shadow egdes.
Farther the light / smaller the light to the subject, the harder/harsher the light, ie crisp well defined shadow edges.
Yes, the ISL applies to all forms of radiated energy, not just to light.I understand Light fall off, similar effect to radiant heat from a fire in the woods.
So that's where they are!Well, it's been there for more than a year, and it replaced an earlier one from years earlier . . .
The reality is that nobody reads my tutorials unless they feature naked women![]()
Being in a smaller room can mask a lot because it creates bounced fill light if you don't take steps to prevent it. And if there is a lot of fill/ambient, then the primary light source can become less dominant to the point it doesn't much matter. That's how a lot of beginners create soft light using the wrong lighting; they unknowingly turn the entire room into a light box.Those differences are very subtle to my untrained eye,
Power was adjusted. I probably should have done a better job when I created the lesson these were taken for, but that was years ago.Was the power output adjusted for the different distances or was it auto type situation ?
Thank you for clarification and for such a fantastic explanation and illustration !Being in a smaller room can mask a lot because it creates bounced fill light if you don't take steps to prevent it. And if there is a lot of fill/ambient, then the primary light source can become less dominant to the point it doesn't much matter. That's how a lot of beginners create soft light; they unknowingly turn the entire room into a light box.
And the finer details of lighting are pretty subtle a lot of times.
You're testing it with continuous light?just "E" all the time
I have read that manual dozens of times, I have the printed manual and all attachments, the full kit, unless perhaps I am doing something fundamentally wrong?You're testing it with continuous light?
Have you set it to measure continuous light?
When you press the Mode button, right after Ambi fstop is flash (then flash multi)auto, ambi, ambi fstop
Thanks, I will try that, did not think of that!When you press the Mode button, right after Ambi fstop is flash (then flash multi)
It couldn’t be more straightforward
Then you don’t need to connect the flash to the meter to fire the flash, you can hold the meter near the subject and fire the flash with your other hand (camera, trigger, whatever)
Does it measure the ambient light OK?tried it, with manual activation of flash, lowest power 100 iso various shutter, still "E"
Think its faulty
Set ambi, a shutter speed and ISO copied from your DSLR that you know will make a reading.
If it works for the ambient, then set the mode to flash, ISO 400, SS of 1/100 flash on MAX power and see what happens.
I don't understand what you mean by 'various shutter' because sync speed or lower are the only the only usable options, and I'd usually set my SS to a little slower* than sync in a studio to account for triggering. ANd I don't know why you would set the lowest power on your flash, when trying to get a measurement, surely you start at MAX?
*If my sync speed is 1/200, I'll shoot at 1/125 in the studio
I could dig my Minolta meter out to help, but currently up to my eyeballs in building work.
You can learn that, and fairly easily.Ambient is not working,
Thanks for helping, don't put yourself out because I think it may have a fault.
I know that I can work around not having a light meter with the flash.
I am probably being over optimistic in that I wanted to try and learn flash output for set distances so that I can set up without thinking and knowing it will be somewhere right near.
Just beating myself up with it.
Thanks Phil,You can learn that, and fairly easily.
As per my post and Garry’s.
And you learn it by measuring first.
Once you do my suggestion and measure exposure with your camera, you’ll know exactly what ISO power setting and aperture match your flash distance.
So next time you shoot, use those settings and they work.
If you move your flash further away, increase the flash power. And it works from 3ft to 4.5 ft an extra stop, and if you go to 6ft that’s 2 stops more than 3ft. (Inverse square law).
But always I’d still do a test exposure. It’s free, takes a second so why wouldn’t I?
