I've been playing with the new Demb Mega Flip-it! flash reflector...
Here is my review: Mega Flip-it!
And since I've been xxxxxx by some members and mods about linking I copied most of it here... Does look too good, no gallery, no cross referencing... but I really hope they are happy now... :|
Demb Mega Flip-it! Kit is a modular reflector. It includes two reflecting panels: semi-matte Mega reflector and glossy Super reflector. Mega reflector's dimensions are 6.5" x 7", and Super reflector is 5.5" x 6". The panels can be easily interchanged using the Velcro attachment system.
You can also take advantage of the modular approach and create your own reflector panels.
One of the corners of the Mega reflector is cut as a precaution measure. When the reflector is attached horizontally, and the camera is in the vertical shooting position, the corner of the reflector gets too close to your left eye if not cut.
Another difference from the original Demb Flip-it! is the mount. It is bigger now, but still features a collar and a hinge. The new element is an angled Plexiglass arm to keep the reflecting surface farther from the flash head.
The mount can be attached to a flash head with a wide stretchy strap that is secure and convenient.
The diffuser folds flat (not as flat as the original Demb Flip-it!, though) and is very portable.
When the reflector is set vertically, it is more evenly illuminated than when it's tilted forward. Using the vertical positions means that you either lose a significant amount of your battery power (outdoors) or have some light bounced off of a ceiling (indoors). In return you get a large even source of light, and that is the idea behind the Mega Flip-it! design.
In case you want to get more directional light, you can set the reflector forward. The Mega Flip-it mount is designed to be set from 45 degrees forward to all the way backwards. When mounting on a wide side of a flash head, 45 degree position allows to redirect all the light forward. If you mount on a narrow side (to be able to switch from horizontal to vertical shooting), keep in mind that with the reflectors included into Mega Flip-it! Kit, some portion of light might still go straight up.
To be able to set a reflector forward, make sure you bring the Velcro base all the way forward before attaching your reflector. This makes the reflector sit a bit higher, which allows you moving it freely.
If you want to use the vertical position only, you can attach your reflector by aligning the Velcro tabs. Thus, the reflector itself prevents you from tilting it forward.
Hare are the sample images taken with Demb Mega Flip-it! Kit: Mega reflector (left) and 8"x12" DIY reflector (right).
Some product shots:
Some product shots:
