stevetiler
- Steve
I'd boot if off a Linux live CD (e.g. Ubuntu), attach an external hard disk and recovery what data you can.
Then reboot it from the recovery partition, reinstall, apply Windows Updates etc. - if you tell us what model of laptop it is, we can probably tell you what magical key combination to press.
There's also probably a key combination that will start the Dell Diagnostic Utility which will run through a suite of tests to rule out common detectable hardware problems.
Can you get into the self diagnostics?
That means that the normal boot partition on the disk is corrupt. Not necessarily the disk itself. You might still be able to boot into the recovery partition.
How do I do that??
So I took the HDD out of the laptop and put it in a caddy and plugged into my desktop, managed to transfer some documents and other bits. The HDD was painfully slow to respond- sometimes would't spin at all !
The recovery partition was showing as empty so I guess there was nothing to recover from.
So I think the laprtop is going to be replaced - some good deals around at the moment!
Thanks to all who contributed to this thread - great advice as always
Steve
Post 14 tells you that.
In a usb caddy the hard drive was slow to respond and sometimes wouldnt spin. I honestly dont think it's worth the recovery
I had the same problem. I wrote this file to disc on my other laptop. switched brocken computer on and inserted the disc. The disc repaired the startup and it has started up ever since. This file was a repair file for a dodgy update.Hi all,
so my sis in law bought her laptop round for me to "look at", on startup (win7) all we get is the screen in the picture.
It just goes on and on ! Is it toast?
ThanksView attachment 64716
That isn't going to fix a dead hard drive thoughI had the same problem. I wrote this file to disc on my other laptop. switched brocken computer on and inserted the disc. The disc repaired the startup and it has started up ever since. This file was a repair file for a dodgy update.
https://www.microsoft.com/en-gb/download/details.aspx?id=38435
I posted this after reading the first few posts as I thought it would help. I missed the post about the dead hard drive hence my post. It is a fact that a recent update corrupted the startup on windows7 and Microsoft put the fix on my link. When it happened to me a friend (a computer geek) told me my desktop was goosed. I tried this fix and it worked, no problems now. I pass this info on as there may be others that are binning perfectly good win7 computers without knowing about the fix. In future though I will read all posts before making a contribution.That isn't going to fix a dead hard drive though
Yes good idea!What she doing with the old one. Possibly still worth £100 without hard drive depending on spec as someone will drop a hard drive in it and install an OS.
Or do it and keep it for the kids?
It might run slow if the caddy is old or trying to send data across an older USB port.
I'm thinking the HDD isn't dead as I can use it in the caddy! Although it does run slow but that could be the caddy maybe?
I meant the pc is usb3 not the caddy!It can't be that old if it's USB3.
