- Alan
- No
We have a problem with a granite top in the kitchen.
The kitchen was done over a decade ago and as a part of all that we got a new ceramic hob, all well and good. After years of service a ring went on the hob and after a bit of research I found that it was best to replace two at the same time (they're in twos apparently and if one goes the other one is likely too) so we lived with the one faulty ring as we never used all four at once and eventually the second one went as predicted at which point I found that it was cheaper to replace the whole thing than to repair the old one. That's when the problem started as when we got a new hob it wouldn't fit the hole in the granite top. Apparently hobs are more of less a standard size hence the the hole should be a standard size and ours is too small. There isn't actually a hob on the market that'll fit our hole and there are no parts available to fix the old one. Argh!
So, the answer seems to be to make the hole bigger to the standard size it should be and fit a new standard size hob. I got in touch with the kitchen fitters who are still in business and they put me in touch with the granite cutters who are also still in business and the guy came to see us. He was surprised that the hole was too small (a cock up in the workshop no doubt) but wouldn't cut the hole on site as he says it makes too much mess with dust and debris so the top will have to come out and go to the worktop and be cut there and refitted but he's worried about damaging the kitchen fittings and tiles. So, we're at a stop really. We can't fit a new hob as they're too big to fit the hole, the granite gutters wont do the job on site and taking it out to cut it could mean damage to tiles and fittings.
I had the idea of leaving the top in place and building a plinth to accommodate the new hob above the hole. that would leave the hob higher than the worktop but we're only talking a few inches so I suppose that would be liveable until we get the kitchen done again, if ever. I've also thought about contacting a different company about cutting the hole bigger just in case they say "No problem guv" but I suppose that could create too much dust debris in the kitchen.
So, I just wondered if anyone had any ideas?
