CS5 help
Mickwreay
Mick
Hi,
I'm trying to follow a tutorial in the June PhotoPlus magazine, which is to add Matte & Frame effect to an image.
So far so good until I try to find the "Window>Effects" It's not an option in my CS5 list under the Window tab :thinking:
This part of the process is to add a Bevel effect frame.
Any Ideas?
dunno about CS5, but just double click the layer itself and the dialogue box will pop up
At the bottom of your Layers tab on the right you should see fx (in italics) if you click on it there will be a list including bevel and emboss.....double clicking layer does the same
Dave
Two ways to Layer Style (you must have a pic open)
If you are starting with a background layer double click on it to make it into a "real" layer.
then double click on that layer and the Layer Style box will pop up
here you need to double click on the style required and then in that box adjust to suit
I find the above way the easier of the two for adding a few styles all at the same time.
OR....
click on the Layers style symbol "FX" at the bottom of the layers palette and choose the style required
this will take you straight to the chosen style dialogue box
BTW the paint bucket tool is with the gradient tool, click & hold the gradient tool in the tool bar and paint bucket should pop up
You are welcome, I teach Photoshop so I have these little bits and bobs to hand
Joan
