Ill have a bashCan you strap a tripod or monopod between the headrest supports? Gaffer tape / cable ties work well.
I did a similar shot with my tripod (independant legs) and had the tripod with one leg in both rear foot wells and the third on the back seat. Was actually pretty steady - enough for night light trails...
I have seen them but they were very expensive mate (Linky). Have you got a tripod ? I was playing about with this idea the other week (Linky) by simply wedging the tripod in between the seats and wrapping the seatbelt around it. It would be alot cheaper unless you intend doing alot of this type of photography ............
think ill try strapping it in if not ill buy something have found a small shop that does them but its still £25 which isnt a arm and a leg I suppose also I can attach my camcorder to it at the ring also I can attach my camcorder to it at the ring![]()
IIRC, on circuit photography is strictly forbidden at the 'Ring.
http://www.nurburgring.org.uk/videoban.html
i know that![]()
Having a tripod or similar strapped to the seat/headrest would be a bit of a giveaway and setting it all up while on the track would be just a little foolish...
For Nurburgring use, if you want to risk recording it, is to have a lipstick camera hidden somewhere, but its a bit risky.
For many other track days they're happy for video recorders to be used, provided the system is attached firmly.
Exactly what I do and very steady. Wedge the third leg betreen the seat and backrest too if you can.
Its actually YOUR fault btw macker im trying to do this now
Have you got a link for that ? I may be tempted to buy one for that much ..........have found a small shop that does them but its still £25
Hehe, sorry mate !
Sorry it's taken a while to post this, but a few years ago I bought just the very thing from Jessops, though at the time it was for use when flying microlights. I don't know if these are even available anymore. All it says on it is "UNI-LOC". Basically it's a strap which you pull tight and then tension with a bar which forms part of the handle. Once in place it's very solid and doesn't shift at all. The head is fully adjustable. Might help someone track down something similar...
Hopefully the pic says it all...
