Capture 1 - 'OFFLINE- Won't batch locate all images...
mrk123
kane
I have 110 images..
A mixture of CR2 and TIFF - I have edited some raw, but some went into photoshop and sdaved as TIFF...
So in my C1 browser ready for export is a mixture of CR2 and TIFF files..
I may have renamed the RAW folder.. So now all images are 'OFFLINE'
I have just tried to locate one, right click on image and locate and it worked but will not batch locate all images.. (and tiffs).
On one image I must have selected a CR2 image over a TIFF and it made my image almost rntirely green...
This is a right balls up!
I have tried to right click on folder but locate is greyed out.
Any ideas... No time to manually locate each one and even then if I get ti wrong it'sd clearly doublled effed up..
OK so I scrolled down to the bottom of library and found the other folder which has all the raw files in and 'locate' is enabled on that folder..
I have managed to locate all RAW now but that one image was destroyed - I will need to now redo that image, there is no way to go back.. tried everything.
Can’t you just rename the folder back? I assume you renamed the folder outside c1?
