Canon Pro 1 Print Size Issue
Portybear
Len
'm trying to print using a custom size on my Pro 1. I input the custom size which is 210mm x 594mm during setup and select fit to page. When the print is complete only half the sheet of paper has the image on it. The image is complete but not to the dimentions that I input. This is doing my head in. Can anyone help?
If you use photoshop you could try another way round.
I am assuming you are using an A2 sheet cut in half long ways (210x594mm)
Open up a new page in Photoshop with size 210x594mm @300dpi (just an example)
Now drag your image into the new page and resize it as you see fit to the sheet.
Print the page and enter 210x594 into the print area.
Tip: always rotate image virtically before sending to print, to match paper sitting in the printer.
Rather than using 'fit to page' I would resize the image to 210x594 in my photo editor and then then set the paper size to the same. I am assuming your printer driver gives you a preview - this should confirm you have it right before wasting paper and ink.
Sorted it guys. I'm now using Print Studio Pro instead of printing from within ACDSEE software. Thanks for your input.
