theres a lot on the web about sigma and high drain rate. i have read that once you switch on and focus the os starts up and does not switch off until you switch off the camera. easy way to check activate the os and wait till the camera goes into standby and see if the os is still active by moving the camera
That is true,i have the sigma 17-50 IS 2.8 lens & the camera will keep trying to focus as long as the camera is on.theres a lot on the web about sigma and high drain rate. i have read that once you switch on and focus the os starts up and does not switch off until you switch off the camera. easy way to check activate the os and wait till the camera goes into standby and see if the os is still active by moving the camera
That is true,i have the sigma 17-50 IS 2.8 lens & the camera will keep trying to focus as long as the camera is on.![]()
I think from memory its in the custom functions:c.fn 2 autofocus,i think its in there you can have it continuous af or not.![]()
hmm ok i cant seem to figure how to switch off this behavior so i have just turned off OS for now. Its definitely something to do with the OS on my lensStrange my lens no longer does that,maybe i changed something in the settings but don,t ask me what.![]()
i think its to do with sigma not the camera as my 70-200Lis doesn't seem to do it it goes to sleep when the camera goes to sleep
Is the OS definitely staying on? It's not supposed to!agreed, just need to figure out a way to stop the lens doing this.
