Cameras at the ready! Incoming Meteor shower!!!! :D
Jake
Jake
People,
I've just found out that on Sunday between 11pm and 2am is meant to be THE best meteor shower this year, and best of all, forecast crystal clear skys.
So if you haven't got the following go get it
Tripod
Remote shutter
spend saturday finding somewhere nice and high, free of any city and street lights to get some good pictures should be good to watch, Dad and other family members are coming to watch, I'm going to snap!!!!
If I find any more info I'll let you all know.
Thanks for the heads up, but the best meteor showers are normally November though aren't they?
The Perseids meteor shower reaches maximum activity during the night of the 12th-13th when given a clear sky some 60-80 meteors per hour can be expected.
The Moon is new on the 12th so conditions could be excellent. The radiant, from where the meteors appear to come, is between Perseus and Cassiopeia.
The meteors can appear in any part of the sky but, if belonging to the Perseid stream, their paths trace back to this area. The real paths of the particles are essentially parallel when they enter the Earth’s atmosphere and the apparent divergence is an effect of perspective. Like most meteor showers, numbers build up over the days before maximum but drop off fairly rapidly afterwards.
The Perseids and the December Geminids (also favourable this year) are the two most reliable annual showers. The Moon will spoil the major showers in 2008.
So before dawn on Sunday if there are no clouds will be the best time to see them - face North (if you're in the UK) find the tip of the Plough's blade (In Ursa Minor) and follow that up and to the right. Perseus should be at the top of the sky as you look around 4am.
Don't know the first thing about how to photograph meteor showers though!
“Almost anywhere in the Mediterranean should be ideal, as long as you are away from artificial light,”
For the first time in my life I'll be in the right place at the right time, and it's as black as yer 'at in my village at new moon time. Yippeee :banana::banana:
Now all I've got to do is stay awake, that could be difficult.
Thanks for the heads up :thumbs:. Might see if I can get out :)
Hehe, I've been to the Bahamas and seen their clear skys, amazing sights :)
Sleep during the day! and huzah! you will stay awake :p
What lens/aperture/shutter speeds would be suitable for capturing the meteor showers? I'm thinking of using my Sigma 17-70 at a wide setting with a narrow aperture and a slow speed. Should I be thinking in terms of several seconds? Alternatively I could use my nifty fifty. Any suggestions?
Might give this ago on top of the pennines, see if I can see anything.
The last big meteor shower I witnessed was right above Grassington Tom, Bloody fantastic but the downside was I had no camera with me..:thumbsdown:
Cheers for the heads up, might give this a try!:thumbs:
It was mentioned on this months Sky at Night so I already had it in my diary.
So I'll see you all on a dark lonley road somewhere then :lol:
anyone know any directions this might be happening in?
cheers for that, i will have my camera at the ready even though i havent taken any decent starry sky shots without something being wrong.
Copied from StarDate Online
The next meteor shower is the Perseids on August 12. This year there’s no moonlight to interfere. The best time to watch is from 11 p.m. August 12 until dawn the next morning. The best direction to watch is wherever your sky is darkest. If you have a dark sky, you may see a meteor once a minute on average. The shower is also active for several days before and after its peak.
Or for the more technically minded.
British Astronomical Association said:
Perseids
Active July 23-August 20
Radiant RA 03h 04m Dec +58°
The undoubted stand-out for meteor observers in the summer of 2007 is a very favourable return of the Perseids, peaking on Aug 13d 02h UT in dark, moonless skies. At this time, just as dawn is approaching for observers in the British Isles, the Perseid radiant will be high in the eastern sky and from locations away from artificial light pollution rates of around a meteor per minute should be attained. In most years, the Perseids produce corrected ZHR around 80 at maximum, with rates at half that level on Aug 11-12 and 13-14. Indeed, watches on any night in the 10-day interval centred on Perseid maximum are likely to be very productive for the patient observer: this is a great time for new observers to try their hand at meteor work! All else being equal, best rates are found when the Perseid radiant – near the ‘Sword Handle’ on the Perseus-Cassiopeia border – is highest in the sky during the pre-dawn hours. Even in early evening, however, the radiant is already quite favourably placed:
Local Time (53oN) Radiant Altitude Local Time Radiant Altitude
21h 28.1° 01h 52.8°
22h 32.8° 02h 59.3°
23h 38.4° 03h 67.1°
00h 44.7°
Observers should bear in mind the nightly eastwards ‘drift’ of the Perseid radiant e to Earth’s orbital motion. In early August, the radiant is 15 degrees west of its position at maximum (given above), to the north of Andromeda.
New Moon falls on August 12, and the Perseid maximum night of Aug 12-13 (a Sunday to Monday) will be free from lunar interference. Productive watches become possible from about Aug 6-7 onwards, with the waning crescent Moon retreating into the morning sky and rising later from night to night.
Perseid meteors are produced by debris from Comet 109P/Swift-Tuttle. Incoming meteoroids have atmospheric entry velocities of 60 km/s, resulting in very fast meteors. A healthy proportion of Perseids are bright, making the shower a good target for photography. Perseids brighter than about magnitude 0 can be captured at film speeds of ISO 400 or greater with a camera fitted with either a 50 mm standard lens or 28 mm wideangle lens at f/2.8 or faster, using time exposures aimed towards Cygnus or the Square of Pegasus. These need not be driven – ‘static’ cameras yield images with meteors appearing as longer streaks cutting across the short arcs of star trails. Users of conventional film can try exposures of 10-15 minutes’ duration. Some observers enjoyed success with digital exposures of 30 seconds’ duration in 2005: obviously, these demand availability of sufficient memory as a night’s operation may amount to as many as 500 images!
Being fast meteors, Perseids – particularly the brighter examples – often leave behind persistent ionisation trains.
As one of the year’s most consistent very active showers (alongside the Quadrantids and Geminids), the Perseids justifiably enjoy favour with even casual observers. The 2005 return was well-observed from the UK, showing a typical strong peak with ZHR 70-80 and the usual abundance of bright events. It appears that the enhanced Perseid activity attending the 1992 perihelion return of the parent comet is now behind us, but the shower’s regular, fairly dependable performance makes this a continued highlight of the meteor observer’s year. Circumstances of the shower could hardly be more favourable for the UK in 2007, both in terms of the absence of moonlight, and the timing of maximum: observers should make the most of this opportunity – moonlight will severely restrict viewing in 2008.
Observations of these, and other less-active showers, together with sporadic activity, will be welcomed by the Meteor Section. Observing instructions can be found on the website at http://www.britastro.org/meteor
Send reports and enquiries to the Meteor Section Director:
I just spent an hour gazing at the sky here in Norfolk and saw over 40 meteors.
Naturally my f-ing 20D chose this opportunity to break down for the first time ever and refuse to turn on. Any ideas folks? (And yes, the battery is charged! :p)
:thinking: But it's Sunday night it all happens isn't it? :lol: (that's for Adwright BTW)
So I have a question... If I was to set my camera up pointed in the right direction, what settings are best to use (using my 350D, please give me a break down of numbers etc.) if I were to do, say ... a 3 hour exposure? :dunno: And would my battery (no battery grip) last a 3 hour exposure if it's been fully charged? Or is 3 hours far too long? :lol:
Ideally (and as far as I know) you'll need to expose for roughly 30 seconds, at a low iso, with a wide open aperture (or just under) and have the lens set to manual-infinity (∞) focus.
The problem with longer exposures is that you would need to introduce some method of tracking the stars (mounting the camera onto a motor driven platform) in order to counteract the rotation of the earth and avoid having the stars etc streak across the image (Ideally you want the stars to be sharp and clear, whilst the meteor moves across the scene).
3 hours would look pretty bad, at least in terms of portrayal of the movement of the meteor in relation to the stars (lots of small streaks).
As for the battery, so long as it still holds 'good' charge and is fully charged it should be fine between 12-4am. Try experimenting with exposures around 20 secs to a minute (at least that's what I'll be doing, might have a pop at a 3-4 min exposure too). You'll need a shutter release cable though (RS-60E3 for the 350d - bout £25 from jessops/jacobs), and try to use the cameras 'mirror lockup' function, and 'long exposure noise reduction' :).
Thank you Benneh! ;)
I also came across this page CLICKY for anyone else interested in finding out settings and all that jazz. It, like Bennah's advise is very useful :thumbs:
Or less than £10 on e-bay :lol::lol:
Anyone fancy a northumberland meet? We can find somewhere up in the cheviots perhaps.
I assume that tonight won't be too bad for viewing the shooting stars either? I was just wondering about doing a short practice session tonight to see what I need to brush up on (especially focus) before tomorrow night.
Typical I just went out in the back garden with a compass and north east aims straight over the only street light in the whole road outside the front of my bungalow :shake:
Well I just came back from tonights sortie and I didn't have any luck catching a meteorite unfortunately. I did see three in about an hour and a half though. Two out of the corner of my eye and the third I was looking directly at. They are huge, a lot bigger than any I have seen before so it is well worth going out tomorrow if you can.:)
I forgot my remote tonight so I was restricted to max 30 second exposures as the camera (or my stupidity) didn't seem to let me use bulb mode without holding down the shutter for the entire time.:bang: I'm sure I used to be able to.:thinking:
Anyway I'll post a few shots up in a bit when I have had a look at them.:)
EDIT: The only showable shots here.
I had a quick look at the sky last night (about 12.30am) and saw about half a dozen in around 5 minutes including a couple of big ones, most of them were just to the right of the North Star, I might have to give this a go tonight.
It's quieter tonight than last night so far, I was up until 4 and didn't get a sausage hopefully it will get more active later, but I can't go until the same time today.
Well i wanted to be up by the marshes for 11pm, but discovered my shift tonight is 11pm-2am :( So I was a little gutted ... until, that is, I just read this on a site:
I usually follow the predictions of the Royal Astronomical Scoiety of Canada, and if they are right with the prediction of 5 hours UT on the 13th, the radiant will be quite high overhead for observers in the UK just before dawn. So the meteors will be well placed for you, if at an inconvenient time. Some place clear and dark from maybe 3 a.m. to 5 a.m. should work well if the weather cooperates. Good observing!
:clap: My night shift may well have done me a favour being early for once :lol:
Anybody caught any? I just spent about 40 minutes trying, but I don't think I managed to get any thing. :(
Been watching and saw loads, a dozen or so over 90 mins - a really beautiful sight!
But I was watching rather than photographing - next year maybe!
