realspeed
- Bazza
- No
I did come across a couple of annoying things with the coil cable supplied with this Azden SMX-30V microphone in this particular setup the connectors on the cable were straight fouling the camcorder body. Easy solution by using right angle connectors instead. the other thing was the cable kept banging against the microphone or camcorder which could be heard in the sound track. again simple answer is by using 2 small cable ties to lock the cable down from moving. This also allows for the coilin the cable to be out the way.
