Hi,
I get through many AA's for devices around the home, and in flashgun etc.
Previously I've had a "Soshine SC3" which promised a lot, but now tends to simply flash the lcd after a few minutes and/or cook the batteries. I have a suspicion that rather than the same device as a similar sony, it's a cheap clone which doesn't do what it's documented to do!
Yesterday I picked up an "Ansman Max E Speed charger set" at a photo show. It's a local LCE show so I'm sure could be returned (unopened).
Whilst I didn't get it from these guys here's a picture/info http://www.tantronics.co.uk/acatalog/copy_of_ansmann_maxe_Battery_Charger_1.html with more
Details are at http://www.ansmann.de/cms/fileadmin/ansmann-www/pdf/2009_ANSMANN-Catalouge_de_gb.pdf
I wanted to get a respected brand, and get a device that does delta-V, temp, timer monitoring. This box does. HOWEVER I noticed that it doesn't monitor individual cells - they appear to be paired. Even though I usually use in pairs, this could lead to insufficient charging.
But I need to balance that against general quality/price. For most chargers on the market I can't even find the kind of information you can see on p28 of the second link, where there's a detailed matrix of capabilities.
It seems the first charger in this range to actually "tick all the boxes" is the energy8 ie http://www.amazon.co.uk/Ansmann-520...1?ie=UTF8&s=electronics&qid=1270161259&sr=8-1, but this is around double the price
Any thoughts on value for money and if this charger is otherwise pretty good (compared to a cheap/undocumented one)? Or is the paired charging such a bad idea that I should return it?
Nigel.
Nigel.
