Bag for: A7RII, 85mm GM, 24-70GM, Batis 18mm, Zony 55mm, Tripod
Jeffs
Hello,
I've recently picked up the 24-70mm GM Bag but my Tamrac Mirage 6, side loading bag is only big enough for one extra lens (in the lens section) if I keep the 24-70mm on the camera. I'll be using the 24-70 a lot, so I really need something that will let me keep that on the lens, while still storing the other lenses, including the big-ish 85mm GM.
I'm pretty sure that I want a rucksack bag, and it needs to hold:
A7RII
Sony 85mm GM
24-70GM
Batis 18mm
Zony 55mm
Tripod
I want a bag that I can access the lenses on without having to remove the tripod and I also need the back to store all the lenses in a proper lens section with a small 'day pocket'. I'll likely have my air blower in the day pocket there, sometimes a Godox V860ii and trigger, or a Gorilla Pod small extras etc. I think I'll probably keep the Tamrac bag and use that when I want to go out with just a couple of lenses.
Any suggestions on a bag that can hold all this (but not much more)?
Thanks.
