B&W Conversion
  • Thread starter Thread starter RobbieW
  • Start date Start date
R
RobbieW
Guest
If I have a colour image that I wish to convert to B&W, hows best to do it? from my limited knowledge I know of 3 ways, these are within the RAW software, change to Black and White, within Photoshop select de-saturate, or within Photoshop select the chanel mixer in monocrome format. With the third one I am not sure how to best set the source channels.
Any help would be appreicated.
Rob
Photoshop channel mixer is the best and most versatile method. The default setting is 100% red channel, change this to 0 and start at 100% green channel (with a tick in the monochrome box obviously). Then play with the slides until you get a result you're happy with. No hard fast rules other than it's best to try and make sure the value of the 3 channels doesn't exceed 100%, although I've pushed this up sometimes and got very pleasing results.
This is a useful site to have a look at Rob, it gives a brief run down on the most popular methods of b/w conversion. HTH :)
