definately get onto Aperture Priority & shutter priority before progressing onto manual, make note of the effects of aperture and shutter speeds and start to learn.
If you're not going to do that all you need is a point n shoot camera
I'm a huge believer in P mode personally. No different to using any of the other auto modes (A & S [Av & Tv]) or even M and the in camera meter. It's knowing when to change the shutter speed/aperture and distrust the meter and add/subtract exposure.
Recently bought a canon eos 450d but all the photos taken have been on auto or scene exposure mode, should i be trying out on manual or is that only used in special circumstances ie low light etc...
Don't get me wrong, I'm not knocking P mode, it can still be the best mode to just grab spur of the moment shots.
You should learn MANUAL before anything else.Everything came after manual not before.You will be able to take photos under any conditions that way.There are many instances where the auto modes will let you down badly.If you understand manual you will know what is happening in the auto/program modes and will know when it is correct to use them.All DSLR have in camera TTL light meters now so it's not difficult to learn manual.![]()
Nope.
Learn how your meter works. Understand how it measures a scene compared to what you see and what you want to portray.
Then you'll be able to use any mode and you'll realise that they're largely unimportant, that sometimes choosing a suitable aperture and having the camera look after the SS can be fine, that sometimes M is quicker than messing with a semi auto mode.
If anyone thinks that using M and just chasing the centre meter reading is in any way being in control, they've spent too much time learning the wrong stuff.
Read my post Phil FFS::shake:
Forget the suggestions from everyone else.
Nope.
P mode does exactly the same as Aperture or Priority. If you program shift you choose your aperture or shutter speed just the same as in Aperture or Shutter priority so not sure how it limits the user to snapshots?
That's why people have lessons.Some very good ideas here but we do feel that everybody here is entitled to make a contribution.![]()
If you were given the keys to a car, a new piano or whatever analogy you care to use & someone said "just go and learn about this & this" or "just try messing about with it & see what results you get, then learn from them" how far would you get?That's why people have lessons.
Nope.
There's absolutely nothing wrong with using a DSLR as a point and shoot
Saying that, the other options will open up new avenue's of photography![]()
no point having an slr if you are going to let the camera take the photo.
