Ah, but *why* were early computer monitors 4:3 [sic]? And *why* were film cameras 3:2? You haven't really answered the OP's question....Because early digital compacts took pictures designed to be viewed on a computer screen (they used to be 5:4 before we all went widescreen).
The 3:2 of DSLRs comes from the movie film some European camera makers decided to utilise in their 'compact' form cameras.
4:3 is pretty close to the angles of human vision and was also the early standard ratio for 35mm movie frames. Old CRT TVs (old as in C20th!) were built to show that format so it made sense to use that format for computer monitors as well. In fact many of the early "personal computers" (BBC B, Sinclair etc.) would be plugged into TVs rather than their own dedicated monitors. When miniature still photography turned to using short lengths of cine film (35mm/135), the film was turned sideways and so the height of the frame was the same as the width had been in the early days of moving pictures - 24mm. Since the pitch of the perforations in cine film meant that each frame was 4 perforations (sprocket holes) tall, someone (presumably Oskar Barnak) decided to use double that as the width of a still frame so a 4:3 frame doubled up keeps the 4 part the same but gives us 6 wide - 2:3, rotated 90° to end up as 3:2.
While the group that developed the four thirds system claim that it has nothing to do with the old monitor/TV ratio, I think it's too much of a coincidence BUT the format does have a precedent in the film world - 6cm x 4.5cm.
what can be concluded from this thread is that there is no perfect aspect ratio.
There was also a precedent with 35mm film. Half frame was 18mm x 24mm which is also 3:4
