Articulated camera stand/mount - advice please
superpippo
Alan
Friends of mine wish to catalogue a set of prints varying in size from small to A3, with a few larger than that. They wish to set the print flat on a table and photo from above with either a smartphone or small compact. They have been looking at YouTube and seen this sort of thing
View: https://www.youtube.com/watch?v=43FmiRYnwRc
but they are not sure if they have the skills or patience to copy that.
I don't know whether something like this would work https://www.amazon.co.uk/Manfrotto-...era+stand&qid=1578678317&s=electronics&sr=1-3
but I can't see how it fixes to the table.
There are other cheap things online and as long as they do the job that would be ok - it is not a long term thing.
I have a decent Manfrotto tripod that I could loan to them but it does not have a horizontal arm. Are there boom arms that would fit and extend over a table?
Does anyone have any experience or knowledge of equipment to do this sort of thing?
Can you reverse the column (or the legs) on your tripod so that you can hang the camera underneath it ?
Could the prints be stood up or attached to a wall?
If you can get enough light (day time by a large window) then you could put the print on the floor and hand-hold the camera or use flash.
Thanks Chris @sirch
Not sure about the first point. Will have a look
I have suggested standing or fixing to wall and using tripod normally but some of the prints are very fragile, being 19th century and they are reluctant to do that.
I think that the last option might work but they seem anxious to use the table to get to the height of the windows in their flat.
Given that the camera has to be parallel to the print it could be hard to frame the image with the camera above a desk unless the camera has an articulating screen.
It should work sort of but it's not designed to be freely adjustable, you're supposed to loosen, position then lock while that balanced-arm lamp is designed to be moved freely because of the springs. It's also very short.
https://www.amazon.co.uk/Manfrotto-Super-Clamp-without-Stud/dp/B000JLM4XG/
Yes a mini telescopic boom would probably work, a million and one different varieties out there: https://www.amazon.co.uk/75-135Cm-Lighting-Holding-Sandbag-Telescopic/dp/B00X7PSDAE/
Fairly clunky solutions to the problem though.
Many enlargers can be used as copying stands, it should be cheap enough to pick us a used one these days
This is the same as the one in the video isn't it? It's incredibly cheap - I'm not sure I'd trust it to hold anything valuable.
https://www.amazon.co.uk/FAPPEN-Uni...VSDBVJ7RQQF&psc=1&refRID=S41HEV47MVSDBVJ7RQQF
There are plenty of these sorts of things on Amazon for holding phones or tablets while “reading” them. If they have a smartphone already it would be easy for them to check if it produces a usable result (”cataloging” sounds like quality reproduction is not needed) and if it does then the ‘anglepoise’ type of holder with a Bluetooth shutter release would be an easy way to do it.
  • Like
Reactions: Sky
@Sky , have passed on that link, thank you
@sphexx , thank you, particularly for the advice about the Bluetooth shutter release, which I did not know even existed :):oops: :$
I’ve used the Camkix BT releases from Amazon, about £5, works well. they are good for phone cams generally if you are trying one handed or at an awkward angle. All those phone/tablet stands will tend to bounce if you try to release by hand :(.
