- Alasdair Fowler
If so, could you do me a favour and check if the following setup causes vignetting;
10-20mm @ 10mm (Ideally on a 1.5X crop body) with a standard thickness screw in filter attached on the end, then a Cokin Z-Pro or Lee filter system on the end with 1 or 2 filters. I suspect I know the answer, but ive got my fingers crossed. The reason I ask is because I want a ND10 filter, and a IR filter for my 10-20mm, but im led to believe i'll get fogging or light bleed if I use a non screw in one. So I want to know if I can use a screw in filter + a Cokin/Lee ND grad.
Edit; Just had a thought.. can you get adapter that would allow me to scew the ND filter into the front of the Lee holder. Hmm, this will probably cause vignetting won't it. Why isn't this simple
