tdodd
- Tim
- No
Today I found an interesting analysis of how the power available from a flash gun diminishes as soon as you turn to High Speed Sync, and diminishes further the higher you go with your shutter speed. Results are included for both Canon and Nikon.
It should help explain to those of you battling against bright backlighting or ambient light in general should probably consider using ND filters if you want shallow DOF, rather than simply increasing shutter speed.
http://neilvn.com/tangents/2010/08/02/high-speed-flash-sync/
