After 10 fps Which second body?
Tugster
Tug
Today has been a really eye opening day for me......
I have never really had 10fps to play with until today, it's certainly given me a real buzz again.
The crux of the post is this, My second body today was a 5d2...albeit a great camera, It certainly isnt for fast sports shooting.
Now having being spoilt with the high fps, I want another high frame rate body as a second body...for either 135mm or for the 70-200mm
I need a bit of advice on this matter.
Points that I am pondering over are:-
1. Body has to have High fps
2. I dont really want another type of battery and charger to lug around with me.
3. I want a body that is both accurate in exposure and also has good reliabillity.
4. Crop factor is important as I use a 135mm, 70-200mm,300mm and 300mm plus 1.4TC
5. Cost....Second user is prefereed as Im probably going to stick a load of actuations on it... so second user will mean I dont loose too much on a body with high actuations.
6. Budget --- Up to £1200
I think that just about sums up my thoughts and requirements...
Which body ?
It's gotta be a 1dMKII at £750ish (Great Camera from experience) Or a MarkIII If you can get lucky at £1200. Mark II is 9 fps Mark III is 10 fps
Keep your eyes open and wait for a Mk3. Dont bother with a MK2 as it is two generations below the MK4 you have just got and you'll just be dissapointed with it.
MKIII to go with your MKIV, I think the MKII or N would be to great a gap between your bodies, I found that between my MKIII and MKIIN at high ISO.
MKIII's are coming down to that price on the 2nd market
as above.. my second camera is a mkIII .. same battery is a bonus..
BUT I totally messed up big time last week when i arrived at basketball with a mkIII when i thought it was the mkIV :( i hadnt gotten around to calibrating the 85mm f1.8 lens to it either :(
I wasn't aware that the MK3 has the same batteries...Well its a simple choice now then....lol..
Just need to wait for a relatively low actuation model to come along with a £1200 price tag.
Cheers guys...:naughty::naughty:
unlike the mk1 and mkII you cant check for actuations unless you send to canon :(
