Hi my nikon 300mm 2.8 lens was being repaired by nikon for faulty motor and estimate came in at 1690 to repair. Lens come back today and this is what it said on repair dispatch note.
Fit new spare parts, as listed, SWM was not required however the inner housing unit was causing the AF issues and this part has been replaced.
Infinity focus and lens resolution checked.
Lens communication and Aperture function checked.
AF functionality and accuracy checked - recalibrated if necessary.
Focus ring functionality checked and ajusted if necessary.
Elements cleaned and optical alignment checked.
Check, test and clean equipment.
Would the inner housing cost as much as a motor? Even tho the quote is based on a motor.
Nikon not sent price for parts used.
kevin
kevin
