- Dave
I'd appreciate some advice and opinions about fibre broadband from Virgin Media.
At present we get our broadband and landline phone from BT via the usual copper phone wire. The reliability is beyond compare but the speed is poor(6 Mbps download and often less than 1 Mbps upload on a good day, and even the BT website suggests the speed range is 3-6 Mbps) so we are considering moving to fibre.
Virgin Media have installed fibre in the street so it is the obvious (and only) one to go for.
I understand that a bit of the front garden might have to be dug up(though I'd rather avoid that if possible) and a hole drilled in the wall to get the cable in.
What happens after that is what I'm not clear about.
The current setup has a phone socket downstairs and then the wire goes to a first floor room where the router is located with two PCs linked to it by wired connections. All the other devices connect wirelessly.
If we wanted the PCs to be connected to Virgin fibre broadband by wire/cable(don't know what is the correct term) would we need new cabling to be installed, or can the Virgin fibre be connected to the existing copper phone wire inside the house?
I suppose I'm thinking of FTTC where, if I'm correct, fibre connects to the a cabinet in the street and then it is copper wire to houses.
I'd prefer wired connections to these PCs but would go wireless if new wiring was needed.
I'd also be grateful for any opinions from anyone who has (or has had) Virgin fibre broadband – how reliable is it, is the speed good, is the wireless range of the router good (the house isn't big but is has a fair bit of water pipes and electrical wiring), any other problems?
Dave
Dave
