fortyseven
Hi.
I'm getting close to launching an antiques business and was recently trying to learn what I'd need to add value with some better photographs.
I read a fair bit about studio lighting and saw the cost of equipment..... I'm poor and everything I have gets spent on stock. I decided to research what was best in the past and to see if I could bring down costs without compromising quality. I appreciate I won't have modern things like radio triggers, lightweight lamps etc..
The workhorse of the past seemed to be the Gemini gm500s so I was researching those as an option. They're cheap enough second hand.
Then a lot came up at one of the auctions I go to for stock, comprising of.....
2x Gemini gm500
1x elinchrom style 600
1x elinchrom style 300
4x tripods
2x padded carrying bags
The lights all had inspected stickers from 2022 so I figured it was likely they still were operational. I took a punt and I managed to get the lot for £52.
I appreciate these are old, bulky, heavy and outdated but they will be staying in one room for product photography only so no issue with bulk/weight.
They've come with wires I assume go to a sync/trigger type affair but tbh I have no idea....
I have tested and inspected everything, they all work except for a modelling bulb which needs replacing. One of the tripods has a collar on the top that doesn't fit into anything, I'm assuming I can buy some type of screw on adaptor?
I'm feeling well out of my depth really. I'm planning to use these for photographing furniture, some large pieces but also for some very small jewellery etc and everything in between.
I'm hoping this thread can be a place I can ask for advice as I progress, right now my main question is what do I need to sync/trigger them together really?
Also, just opinions in general, I'm a fast learner and competent at most things I turn my hand to but I feel I might have bought obsolete problems for myself. It was an impulse buy really. It's only £52 but if I can't make them work it's £52 wasted...
Sorry for the rambling post. I'm still a bit dizzy from carrying these heavy s.o.bs from the auction to the bus station, then from the bus station home.
Any advice for a noob appreciated. Thanks in advance.
2x Gemini gm500
4x tripods
