Adjustable table top tripod with ball head.
SsSsSsSsSnake
As per title,I’m looking for a decent one.
It needs to support a minimum weight of 1.5 kilos
ive looked around But would welcome suggestions from users on here,
thanks
How adjustable are you talking about?
I have a Momam(not sure I have the spelling right)....
Edit
I bought it without a head as I use the one from my old Manfrotto table tripod when needed.
I bought it with the intention of using in a hide and it, for me, worked well as an alternative to a hide shelf plate :)
Edit
I have one of those and rate it very highly.
that looks ideal, can you recommend a ball head that would be suitable?
maybe this. does it just screw on to the 1/4 screw or would I need to change to the other size you get with the tripod?
If I did not already have the old (small ) ballhead I would have likely bought that one.......as well reviewed like the tripod.
FWIW I have the tripod, as mentioned, in a hide to support my gimbal & leveling head combo. With the legs splayed flat it felt as solid as a rock:)
I have one of them, it is excellent, and the quick-set button is the best idea ever!
As long as the load is balanced at the mounting point it will take 1.5kg
I have one but unfortunately I need something to take 2 kg I put the load on this same tripod and the ball was not solid enough. I need to be able to tilt the ball down
Too big? Too Expensive?
I have one, its a great piece of kit.
It's not the same one. The one I linked takes 2.5kg.
That's not what I linked to. I have the smaller version as you appear to as well. The one I linked takes 2.5kg.
Edit
Also available with a head as the Marsace MT-01: https://www.amazon.co.uk/Marsace-Ta...=marsace&qid=1663598357&s=electronics&sr=1-22
