Im going to buy a Cokin ND kit and adaptor to fit the 5d Mk2s standard 24-105mm lens. Id also like to incorporate a circular polarizing filter. Should I assume a screw on filter will be sufficient for this? Ive seen filters which are rotatable, does a screw on filter have the same effect by just loosening and rotating it? I assumed also there would be a filter to fit the Cokin kit, but this wouldn't be rotatable individually, which would be an issue with an ND grad? Thanks.
