jerry12953
- Jeremy Moore
- No
Having last night changed certain images from 16 bit to 8 bit to convert them into jpegs, should I return them to 16 bit now? What difference does it make?
Perhaps i should have converted a *copy* of the 16 bit image to 8 bit for conversion, then, if its not possible to go back to 16 bit?
What's the difference between 8bit and 16bit anyway?
8bit has 256 shades per channel 0,1,2....,253,254,255
16bit has 32768 shades per channel 0,1,2...32765, 32766, 32767
so you can smooth gradients as the changes from one shade to the next are much more subtle. The downsides are larger file sizes and limited support for printing, most labs can't handle 16bit and of those that do most will convert to 8bit for printing anyway. The RAW file from the camera is only 14bit (at best) to start with and the noise will usually mask any really smooth gradients 16bit could provide so although on paper it sounds great the advantages of 16bit are somewhat limited without moving to 16bit medium format digital backs.
In reality no. You could get uber geeky about the whole thing but the only person who's going to tell the difference is another uber geeky person. Let's face it most people who look at a print don't even know what white balance is let alone being able to spot the difference between the tonality from a 8bit or 16bit print.
