- Richard
- No
I wonder if anyone has experience of 5g home broadband? I currently have VirginMedia cable on a contract finishing next month, it’s 125 Mbps and I use a TPLink Deco Mesh system which is resricted to 100Mbps and all works OK, for £24 pcm jumping to £50 odd at end of contract. Of course I could upgrade to VM M250 for £33 or bargain for a new deal and so on.
However I’ve just received a Three 5g Home Broadband Hub/Router on “approval” and a £24 pcm monthly “contract” (or could opt for £20 pcm on 24 month contract).
Three say I’m in a “Good” outdoor area and “Very Good” everywhere.
I think the nearest mast is about a mile away but I’m on a hill with almost line of sight to it as the ground falls away towards it.
Three advertises an average speed of 150Mbps for it and I’m getting 50-400 down according to Ookla Speedtest — seems to vary wildly but most of the time I would say it’s 150 or above though their app rate it Poor or Fair. The Hub will drop to 4g if 5g unavailalable but I’ve only seen that once and the speed was very good. The speed up is mostly less than the 20Mbps I get from VM.
If anyone is interested the setup was a doddle but changing anything from the defaults is a nightmare. The iOS app works mostly but so far I’ve been unable to log into the web interface despite entering the correct details and resetting the Hub. During setup I was invited to change the WiFi name and password , which I did and was accepted but later found it was still on the defaults.
I haven’t seen any problems from a user point of view over 3 days use so I’m minded to stick with it and chuck VirginMedia. My only doubt is that I need to run the Deco Mesh from it for which I should switch the Ethernet output to modem mode (if I’ve understood correctly this can be done via the web interface and maintains the Hub’s WiFi signal unlike on my VM Hub. However at present the Mesh is just connected to the 5g Hub’s Ethernet and everything seems to ”just work” ™.
The only other drawback I’m aware of is that outages are said to be more frequent than with fibre but I have a mobile phone on a different network though I did away with my landline.
