Looking for a 2nd hand DSLR
Budget £150 but may stretch to £200 and will have to be a Canon (I've already got Canon EF and EF-S Lens)
So in mind I've got the Canon 20D
TIA
20D is a great camera. LCD is a very small though, as they mostly were then.
Can you stretch to a 40D? Just a bit better all round. Can hold its own pretty well today. £350-ish?
I'd rather take the 40D than the 600D myself![]()
I'm curious about this as I've looked into it myself. Spec wise, there doesn't seem to be a huge difference between the xxD and the equivalent xxxD. Must be something I'm missing?
I've only bought a 550D as my first DSLR so I'm a long way away to even think about an upgrade but wanted to ask the question out of curiosity.
... build quality... last longer... 1/8000s ... burst-rate ... brighter viewfinder... bigger size ... top lcd screen, rear wheel, 'joystick' etc.etc
If you're used to a XXXD model - when you pick up a 30/40/50D - you will notice an immediate difference, particularly in weight, size, controls and build-quality.
30D arrived yesterday
Get an error code when trying to format flash card "Err 99"![]()
One of our participants in the long comment thread below (Tom) got this in a message from Canon USA. It may help some of you isolate the problem before you post a comment/question.
To isolate the cause of the issue, we suggest that you do the following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the ERR 99″ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the ERR 99″ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the ERR 99″ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the ERR 99″ with a different Canon lens attached, then the camera should be serviced.
Update #3
Thanks to Alyssa for this tip from Canon tech support.
If you have a later model Canon DSLR that has Automatic Sensor Cleaning try turning that feature off to see if it stops the error. If it does, test to see if manual sensor cleaning still works. If it does youre all set. If it doesnt you should probably have your camera serviced to have it fixed, although you can shoot without this feature if you dont change lenses much.
Youll find the control of that feature in the cameras menu system.
imho (and basing my opinions more on comparing the 350D to the 50D but having some limited experience of the 40D & 600D - enough, I feel, to understand the principle difference to XXXD models and [pre 60D] XXD models) , the build quality of the 40D is far superior to the 600D - metal body, some weather-proofing (I think), parts designed to last longer, shutter life of 100,000 actuations and fast speed of 1/8000s, higher burst-rate, brighter viewfinder (pentaprism vs. pentamirror of 600D), bigger size (easier for me to hande) and much easier controls - top lcd screen, rear wheel, 'joystick' etc.etc. From what I've seen, the IQ is very good too especially with low-noise - but I cannot compare this to the 600D. If you want to explore menus, customisations and features, I expect there are some that are just not available on XXXD models.
I guess it's more noticeable when you migrate from model range upwards. I've only just got onto the SLR scene so quite happy with the xxxD range at the moment. I'm sure an upgrade to xxD range will be justified in a year or two.
