foodpoison
- Sean
I'm sorry if this is in the wrong forum, but this is where I thought it best suited it.
1.
I have seen some really amazing HDR shots, and really like the style of them, the only problem is, I'm not quite sure how to do them. I tried doing an HDR shot pointing outside on a bright day. I took the standard shot (the one the camera set in its programme) then I did 3 half/double shots/brackets either side of the standard. I put it in to photoshop, and basically, my problem was that the clouds had moved, and various other things had changed.
Now, my question is, is there any way for the camera to automatically take the shots in several seconds, rather than putting it into manual mode and changing the settings myself?
2.
I'm looking to buy some filters.
Both my lenses are 58mm, and I don't intend on buying any more lenses for a while. Basically, what I want to be able to do is have long shutter speeds during the day, without the image over-exposing, which I think is an ND filter.
Also, I'm going skiing during the winter, and would like a filter to make the colours a little darker and prevent everything from getting washed out, which I think would be a circular polariser, but I'm not an expert on filters. What would you recommend?
1.
2.
