Mr Pid
Whilst attempting to improve some very boring and dull skies from Great Yarmouth I was playing with the Dehaze, when increasing the slider I noticed these spots appearing which got worse the further I pushed it.
I am not sure if this is oil or just dirt. I have cleaned my lenses and this only shows up on the 1DX body. I cannot see any visible dirt/dust on the sensor and I have cleaned with my airbrush. I havent tried a wet clean yet, although I have the equipment if necessary.
I know there are historical problems with oil on the sensor and I have checked my serial number, (of which 6th digit is 0). The camera has a very low shutter count, less than 20k and you cant see these spots on correctly exposed images.
Any ideas?...
(Obviously image altered to show up spots).
View media item 13254
Any ideas?...
This one hundred times... If you can't see it then it isn't there. If you can see it then do what you need to do but don't go looking for it because you will find it and it will drive you up the wall trying to get rid of all of it.
