18x12 Mount -Where can i get them from
andiphoto
Knock-Off Nigel
Andrew
I have a few 18x12 prints... but i cannot find any frames for these... so was looking at getting a mount for a 20x16 frame to use my 18x12 prints..
any ideas on where i can get these.. . or even if you know of anywhere to get 18x12 frames...:clap:
Most framing shops make frames to size, same for mounts, though you can do both tasks yourself with some gear if you need to do several it may be worthwhile investigating. I have my own mount cutter and use stock size frames for my paintings. Your 18x12 though will look odd with an uneven mount if using a 20x16 frame.
cheers fella ill have a look... i found a website picturelizard... it seems canny.. and apparently its going to cost me 14.49 for a frame and a mount to hold 3 12x12 inch prints :/
