- Graham
I'm having a bit of a quandary here. I need to power an outdoor camera that has a 12V 1A input power and it uses this style adapter (below). It's clearly not been thought out and designed for outdoor installation (even though it is an outdoor IP rated camera):
I've got 240V running outside and I usually use junction boxes and connect floodlights directly using block connectors because it's all 240V. If this was one of those 12V power supply that has a separate cable coming out with a plug (like laptops have) then I could strip the cable from the plug. I've considered buying such a power supply, but that's more expense and I'd need to make sure it fits into the camera.
So, at the moment I'm thinking an external single socket is the easiest option, but is there a cleaner way to do this?
